Hi am using Skype android application on my mobile. Recently I heard the application called tango. And send some helping tutorial explanations for how to use that software, Special features, Main advantages and disadvantages. Suggest some ideas which one is better? Are this tango works with Skype?
Tango application works with Skype
Hi HerbertTBoyd,
Tango and Skype are both VoIP calling application. If you install the application on your phone, you can make free call to users using the same application. However Skype can be installed in PC and other devices and Skype supports chatting, IM, SMS and sending files (SMS with charge) but tango doesn't support this features. The most wonderful fact about tango is it synchronized your phone book with the application and the camera and screen swapping is enable. In Skype to Skype users, video and phone calls are completely free. I think Skype is better for it was there it the VoIP market a long time and is a reputed name whereas tango is new to the VoIP market.
