Task bar disappeared and no start button
Asked By 120 points N/A Posted on -
I have a problem where my taskbar disappeared and there is no start button. This happened after windows explorer opened an unresponsive folder.
I know that this will be corrected if I restart the computer but there is another way to get the task bar without restarting the computer?
At times there are still applications that I am working on and I lost my work when I restart the computer. All the best!
Best Answer by Lonnie Pella
Answered By 0 points N/A #87408
Try Ctrl + Esc and see if that brings up the start menu.
Answered By 120 points N/A #87410
Tried it and still no Start button.
Answered By 0 points N/A #87412
Do Ctrl + Alt + Del
Click File > Run > Browse > (C:) Local Disk > Windows > explorer.exe
Your task bar will show up with the start button.
Answered By 120 points N/A #87414
Thanks man!
Restarting explorer.exe fixed my issue.
Answered By 0 points N/A #87415
Good to know. I'm just adding Windows task manager screenshot.
Windows task manager screenshot file and new task option
Answered By 120 points N/A #87416
Nice addition of visual aid.
Thanks!
