Howdy guys! I attempted to load the task manager but I unfortunately get an error message in return.
C:Windowssystem32taskmgr.exe
Windows cannot find ‘C:Windowssystem32taskmgr.exe’. Make sure you typed the name correctly, and then try again.
Windows cannot able to locate the words that I typed.
Please help me shed some light on this problem.
Task Manager is missing on Windows 7
Hi Jonathon
You should have a virus on your computer. Scan your computer with an updated antivirus and activate it manually. To activate your task manager,
Click on star then run; Enter gpedit.msc ,
Select Administrative Templates
Chose System and then Crtl+Alt+Del Options
Open Remove Task Manager and change the value
It should work.
Thank you
Throughout years, the default "Task Manager" in Windows has always been lackluster. The best possible replacement for it is "Process Explorer", which is available for download by clicking here. Once downloaded, extract it from the archive and run "procexp.exe"
Although at first it might overwhelm an inexperienced user with the sheer amount of data, Process Explorer gives invaluable insight into the functioning of the Windows operating system and provides useful options which Task Manager does not, such as "Suspend Process".
