Task Scheduler 0x41301, A Task That Is Running
The Task scheduler 0x41301 means it cannot start a task. The code 0x41301 means the program is running. If you see that it is still running that means its stuck in some loopholes. It is because it did not properly. To fix this error, make sure you terminate the task properly for this you need to add a ‘quit’ and the Click run, you will see that the result is now 0x0 (successful).
There is another way also you can set a time limit, go to properties, settings, enable the option ‘stop the task if it runs longer then.’ In the setting tab 1 hour/2hour as you want. Now the task will get terminated automatically. You can click on the option to create a task scheduler if the previous is still running.
