Task Sequence Failed With Error Code 0x8000ffff Due To The Partitioning Of The Disk.
Whenever I try to partition the disk for the deployment of the operating system I encounter the error code 0x8000ffff which says that there is a problem in the partitioning of the disk. What should I do now I am not able to proceed further thanks in advance?
