Taskbar resizing problem in Windows
Hi guys,
Almost half of the moment when I use my computer the menu “task bar” is ok with me. But another half of the moment it extends to thrice that’s “normal vertical dimension” and does “vibrates” or “oscillates”. I don’t have any idea what to do and it would be good to provide a screenshot to depict the scenario. For any thing, over the shape which will be again described the jittery taskbar and I am able to manage it sometimes to keep working functionally but it is not easy task for me to do. So what is this problem going on here? Could you please tell?
Thank you in advance for your support
