The TAT7 iPhone Scuba Case
TAT7 iPhone Scuba Case is good especially when taking photos under the water, do you think this case.
It will be also good or fit even without taking out to the iPhone even you are not using it under the water?
Hello Janetsbraswell;
iPhone has a great picture quality, with crystal clear scuba case, you can now take pictures even under the water. the case protects your iPhone while it being crystal clear does not effect the quality of the pictures however iPhone is not designed for underwater pictures.
Other cameras such as seaLife reefmaster mini II, are specially designed for underwater pictures and produce a great result, far superior then that of iPhone. If you don't have a choice then go with iPhone as it will give you respectable results. Using scuba casing without being under water seems like a stretch.
It is not that stylish and not easy to use.
