Tata Speed Plus Software to increase speed of the Internet
Hi Friends,
Is there any Tata Speed Plus Software to increase speed of the Internet, If so what is the procedure used by it to boost the speed of the Internet, will it be able to work with other networks.
Thanks, Abbigailantonia
Best Answer by Martine Paul
Answered By 0 points N/A #198707
Hello Abbigailantonia,
There is no such thing as a booster of the internet speed. If you want a better speed to access the internet, you have to talk to your internet provider. Otherwise, if you are using a tool, then it may be seen as a illegal tool and that is not recommended.
Take care!
Answered By 0 points N/A #198709
Hi Abbigailantonia,
I suggest you should upgrade you internet. Such as Internet Boosters can reduced more of your Internet speed or it might harm your machine. My other suggestion is to install a fiber optic cable (you can ask your Internet Service Provider about this), by this you will definitely have a faster internet connection.
