Hi. I recently purchased and installed TCP IP Logger ActiveX for reading data from a TCP/IP port to Microsoft Office. The program just crashes when launched. What could be the problem? I'm on Windows XP 64 bit Sp 2 and Microsoft Office 2003. Thanks.
Tcp ip logger activex not working
Hi Deanna,
There are few reasons occurring this problem and several root to solve this problem. The software you purchased can be troubled or missing directories. That case at first go to the control panel then administrative tools to service tools. Reinstall the system and restart your pc then if does not work then the program is must be corrupted. If then you found this does not work you can look after you can have another software installed. Get them all uninstall & reinstall or download the latest version of the software you have.
For more information this may help you: https://www.fixyourownprinter.com/forums/printer/68459
Hope this may help you.
Good luck.
What is the version of the TCP IP Logger ActiveX that you purchase and installed? Try upgrading it since there are bugs from older versions that are already fixed from newer versions. And to install it correctly, follow the steps below:
1. Close all the running instance of Advanced TCP/IP Logger and then start the installation.
2. It will be installed to the /Programs Files/Advanced TCP/IP/Data Logger folder by default but you can change it anytime.
3. During the installation, you will be prompted with a confirmation to register TCP/IP Logger ActiveX. If you did not confirm this process, you need to run !register.bat on your program folder.
For more information, click the link below:
TCP/IP Logger ActiveX Printed Manual
If you think it is not possible with Microsoft Office, then there are other options for Microsoft office that can be used like  MatLab and LabView. TCP IP Logger ActiveX 2.5.1.9.1.9 utilities software was developed by AGG Software. The license of utilities software ishareware and the price is $555.70. Before you buy a registration or license, you can download for a free trial. It is not recommended to use warez version, manipulated versions, serial numbers, registration codes, pirate key for this utilities software TCP IP Logger ActiveX. You can only get full and unlimited version of TCP IP Logger ActiveX, if you buy from original publisher AGG Software.
