Hello Expert friends,
I updated the Teamspeak 3 to latest version the installation went without any problem. But the problem triggered when I try to open the TeamSpeak 3 I got an error message that hotkey needs to be reconfigured. How to configure hotkey? I am stuck with this problem, please help me. Your help is appreciated. Thanks a lot.
Important notice
Due to the latest ts3overlay update, your hotkey needs to be reconfigured.
Please open the ts3overlay plugin configuration page and set your hotkey in the “lnput” tab.
OK
Teamspeak hotkey needs to be reconfigured after ts3overlay update [closed]
To make sure you are using the latest version of TeamSpeak 3, download it from TeamSpeak 3.0.14. Make sure also TeamSpeak 3 supports your operating system. For Windows users, TeamSpeak 3 supports Windows 2000, Windows 2003, Windows 2008, Windows XP, Windows Vista, and Windows 7. In case you have Windows 8, TeamSpeak 3 doesn’t support it.
For Mac users, TeamSpeak 3 supports Mac OS X 10.4 Tiger and higher. It also supports Linux. Uninstall the one currently installed on your computer then click Start, All Programs, Accessories, System Tools, and select Disk Cleanup. Select drive C and click OK. Check “Temporary files” and click OK. Wait until it is finished and restart your computer.
Next, run the newly downloaded TeamSpeak 3.0.14 installer and then run it afterwards. See if it works. This error you have may appear if you are using TeamSpeak 3.0.11 that’s why you need to download the latest version to fix it.
