Teamviewer is executing with this website.
Hi Experts,
I am getting an message which displays that ‘Teamviewer is executing with this website.’ I don’t know what is the meaning of it? Please guide me to find the problem.
Thanks in advance.
Hi Experts,
Thanks in advance.
Hi friend.
you don’t say about your Windows and proper message which is shown you on your desktop. Well i have all description;
For windows xp; you may bookmark on this page url or link. you may have some different from your browser. you can use it by team viewer application on your desktop where you can share your computer to prefer team.
Second windows 7; properly install the soft on your desktop shortcut. connect in the internet connection and give your login ID and password to your team. then it will be black on your screen. at last you can browse it.
You do not need to go any website to perform it. but unnecessary installing files can harm it.
Thanks
Team viewer is executing with this website means that the program you tell here will run with the website you are browsing. You can browse the website and this program will run automatically with this program. A team viewer is a program that is used to see the team over the network and it is used when you need to work as a team and want to chat with other members of your team to make sure that all the things are going fine then you can do this by using this program. If you have installed this program earlier then it may execute with the website you install it for. You can also check some settings also in the program to change some type of your program. You will then be able to solve your problem.
Michal joran.
