Teamviewer putty refresh screenshots again
Why teamviewer putty refresh again and again to my screenshots? Is there any windows problem due to installation of teamviewer?
When you have installed Team viewer. Did you face this problem before installing Team viewer. If you are facing this problem after installing team viewer then you need to do this way. Please uninstall the team viewer then reboot your system and see whether you are still observing the problem. The thing is putty will be using SSH connection and team viewer may also be using SSH connection to connect to other computer. If the team viewer is being refreshed then even the connection that is made using putty will also be refreshed as the connection is made to the same system. Please either use only one connection at a time from one system.
Samuel
Notifications
