I want some technical details about Acer Iconia A510, I want to prepare a review about that. I want to know about its camera specifications and performance details and I also want to know about its measures like thickness, length, diagonal length, etc.
The Acer Iconia Tab A510 is an Android OS powered Tabler, which has got all the high-end specifications and an up to date hardware under the hood. The Acer Iconia A510 runs Android 4.0 Ice Cream Sandwich OS, powered by the hefty 1.3 Ghz quad-core NVIDIA Tegra 3 processor, sporting 10.1” HD Multi-Touch Display (1280 x800) resolution, 16:10 aspect ratio, 1 GB DDR2 Memory to keep things running smoothly.
Equipped with a 5 megapixel Rear facing camera with auto focus & 2 megapixel front facing HD camera, 32 GB flash eMMC with memory expansion slot up to 32 GB via microSD card slot, micro HDMI, micro USB 2.0, Bluetooth 2.1, WiFi 802.11n, 36.26 W battery to provide 18 hours of battery life on a single charge, it lengths 10.3 inches width (Landscape) 6.9 inches Height and 0.46 inches depth.
The Acer Iconia Tab A510 is a discontinued tablet with no cellular connectivity support. It was unveiled to the public on February 2012 and released on April 2012 measuring 259.1 x 175.3 x 10.2 millimeters and weighing 680 grams. It doesn’t support SIM card. It has TFT capacitive touchscreen display with 256K colors at 1280 x 800 pixels screen resolution.
It supports multi-touch and runs on Android 4.0 Ice Cream Sandwich powered by NVIDIA Tegra 3 chipset, 1.3 GHz Quad-Core Cortex-A9 processor, and ULP GeForce GPU. It supports microSD expandable up to 32 GB. It runs on 1 GB RAM with internal storage available in 16 GB and 32 GB capacities. The primary camera supports 5 megapixels with AF and supports 720p video recording.
The secondary camera supports 1 megapixel. It has 3.5-millimeter jack featuring Dolby Mobile and active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n, Bluetooth 2.1 with A2DP and EDR support, GPS, and microUSB 2.0. It doesn’t have FM radio. It has built-in accelerometer, gyro, and compass sensors. The pre-installed web browser supports HTML with Adobe Flash support.
It runs on 36 Wh non-removable Li-Po 9800 mAh battery with talk time up to 15 hours via multimedia. It is available in black and silver colors.
1....
