Technical Details about Nokia E7
I am going to buy a new Nokia E7, Still I have some doubts to clear.
My friend said that it has less resolution display, anyone know how much is that ? Is that OK with this phone ?
Is there any extra options available in E7 rather than older versions ?
Answered By 0 points N/A #136777
Here is everything for Nokia E7.
GENERAL 2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 850 / 900 / 1700 / 1900 / 2100
BODY Dimensions 123.7 x 62.4 x 13.6 mm, 104.9 cc
Weight 176 g
Keyboard QWERTY
DISPLAY Type AMOLED capacitive touchscreen, 16M colors
Size 360 x 640 pixels, 4.0 inches (~184 ppi pixel density)
Multitouch Yes
Protection Corning Gorilla Glass
  – Nokia ClearBlack display
SOUND Alert types Vibration; MP3, WAV ringtones
Loudspeaker Yes
3.5mm jack Yes
MEMORY Card slot No
Internal 16 GB storage, 256 MB RAM, 1 GB ROM
DATA GPRS Class 32
EDGE Class 32
Speed HSDPA, 10.2 Mbps; HSUPA, 2 Mbps
WLAN Wi-Fi 802.11 b/g/n
Bluetooth Yes, v3.0 with A2DP
USB Yes, microUSB v2.0, USB On-the-go support
CAMERA Primary 8 MP, 3264×2448 pixels, fixed focus, dual-LED flash
Features Geo-tagging, face detection
Video Yes, 720p@25fps (720p@30fps via an update), video stabilization
Secondary Yes, VGA
FEATURES OS Symbian^3 OS, upgradable to Nokia Belle OS
CPU 680 MHz ARM 11
GPU Broadcom BCM2727
Sensors Accelerometer, proximity, compass
Messaging SMS (threaded view), MMS, Email, Push Email, IM
Browser WAP 2.0/xHTML, HTML, Adobe Flash Lite
Radio Stereo FM radio with RDS
GPS Yes, with A-GPS support; Ovi Maps 3.0
Java Yes, MIDP 2.1
Colors Dark Grey, Silver White, Green, Blue, Orange
– Active noise cancellation with dedicated mic
– TV-out (720p video) via HDMI and composite
– Dolby Digital Plus via HDMI
– MP3/WAV/eAAC+/WMA player
– MP4/H.264/H.263/WMV player
– Voice command/dial
– Document editor (Word, Excel, PowerPoint, PDF)
– Video/photo editor
– Voice memo/dial
– Predictive text input
BATTERY Standard battery, Li-Ion 1200 mAh (BL-4D)
Stand-by Up to 432 h (2G) / Up to 480 h (3G)
Talk time Up to 9 h (2G) / Up to 5 h (3G)
MISC SAR US 0.93 W/kg (head)     1.23 W/kg (body)
SAR EU 0.56 W/kg (head)
TESTS Loudspeaker Voice 66dB / Noise 62dB / Ring 75dB
Audio quality Noise -88.3dB / Crosstalk -89.3dB
Camera Photo / Video
THANK YOU.
