Technical features of USB Type-C cable and its necessity
Is it similar on old USB version cable? Can this charge fast and has ability to multiple tasks on single cable? What is the transformation rate in USB Type-C? Can I connect this into smart phone and tablets? Is it taken to charge 100-watt in USB Type-C cable? Can I use the both ends of USB Type-C cable?
Answered By 5 points N/A #189096
Hi, The most important thing is that USB-C is not a new standard like USB 1.1, USB 2.0, USB 3.0 and the latest USB 3.1 standards. These standards are the upgrades of what the connection can do in terms of speed. However USB-C is type of socket used for physical connection like microUSB and MiniUSB. It is build on USB 3.1 standard that brings speed and power advantages. You can connect it to smart phones and tablets. It will completely replace all types of USB on both host and client devices.
