What are the functions and importance of a laptop keyboard protector? I would like to know technically the importance of a keyboard protector? I went to town with a friend a couple of weeks ago to buy some cables for networking. It was at that shop I saw a keyboard protector and ever since then I have being trying to seek solutions and answers for my quest. I would be very happy if you can assist me in finding answers for these quest. I am Philip and I am ten years old. Thank you.
Technical Importance and Functions Of Laptop Keyboard Protector
There are a number of benefits for buying a laptop keyboard protector, which I will list below:
1. If you are, like me, one to eat or drink near your keyboard often, the protector will keep food particles and liquids out of your keyboard. Liquids can damage the keyboard, while food particles is just nasty. I can't tell you how many times I've eaten near my keyboard and accidentally got a food crumb in there, and then was unable to get it out because when I tried to grab it, I'd accidentally push down the key, and then it would just fall under. I probably had quite a few bits of stale bread crumbs and such.
2. It'll protect the keyboard from dust. It's hard to keep a keyboard clean, having to dust between keys and all.
3. It provides protection from wear and tear. Some people type really hard on their keyboards, causing keys to get damaged. Even if you aren't one of those people, keys will eventually wear down or even pop off. A protector helps keep the keys in top condition for a long time.
4. Most laptop keyboards are plain and boring in appearance. If you're one to like to have a lot of color around you, keyboard protectors come in all kinds of colors to suit your tastes.
Actually, all keyboard protectors have the same purpose: to prevent the accumulation of dust underneath the keyboard and other substances like food particles, water, and others. It is important to keep your keyboard dry especially if it is on a laptop unlike with a normal keyboard used on a desktop which can be replaced easily.
Avoid eating or drinking while you are using your laptop because accidents can happen. Though food particles can sometimes be easily removed under the buttons, fluids or liquids like water or juice is the total opposite. It can immediately damage the functionality of your entire keyboard. When liquid is accidentally spilled over the keyboard, it may drip deep below the keyboard into the laptop’s board.
If the water drips straight into your hard drive, all your data will be corrupted and may be unrecoverable. It can also cause short-circuit inside the laptop. So, when you are away and you left your drink near your laptop, make sure to put on the keyboard protector to protect your machine.
