Technical support required for retrieving my IP
I need to find my ip of my lan connection which will be helpful for me for signing up in different websites of my interest. There are certain websites that requires ip addresses for there sign up process and there can be only one IP for each sign up. So  kindly someone help me where can my find my IP.
Adolfo Brown
Answered By 5 points N/A #106422
Every computer connected to public internet must have IP address.
Every computer has only one IP address that is the internet protocol address and that is the domain identity. A your computer is connected with internet then you must have IP but if you does not then you can find your IP address by going to the following link, as this will tell you address, https://whatismyipaddress.com.
Along with IP it will also give information about your internet provider, location etc. hope by using this link you will find you’re IP and you find this information helpful. Now you can avail those websites easily.
