b.ernie96
10 points
Posted on - 07/27/2016
Hello everyone,
I want to Convert a PDF File to a Word File. But, I do not intend to use Acrobat reader. I will not go for an Online Tool either. I am looking forward to using Foxit Reader to make the change. Someone, please, help.
A Technique That I Can Use To Convert PDF To Word Foxit.
Foxit Reader is just a PDF Reader. You cannot use it specifically to Convert PDF to Word. But, there is an alternative to this situation.
1) Open the PDF file using Foxit Reader.
2) Click on the “Save as” option, and choose “.txt” as the extension in which you want to save.
3) Now, open that “.txt” file using MS Word.
4) Simply, save the File using MS Word as a DOC File.
I will not call it conversion, but it will help you.
