Is there any technique by which, I can set HD things on a normal DVD that will be able to play on blue-ray equipment that are not well-matched with AVCHD?
Or, is there any other programs that makes DVD’s, which would be able to be played on Blue-ray players?
Please help me know it.
Technique to set HD on normal DVD for playing on Blue-ray players
Hi, Yes there is a technique. You can Burn an HD-DVD To Blu-ray and here are the steps:
RIP Data from HD-DVD.
Separate Videos and Audio Streams.
Process Video Streams.
Compress Audio Stream.
Recombine Audio and Video Stream.
Burn Disk to Blu-ray.
I hope this help you.
Good Day!
judah2
Hi Ross,
There is a program that could set HD to a normal DVD that could be played on the blue – ray equipment.
Step 1: Download blue-ray converter.
Step 2: Install and run this program.
Step 3: Select and Load video files you want.
Step 4: Select output formats.
Step 5: Customize Output Parameters.
Step 6: Start HD to blue-ray conversion.
Step 7: The burner will be auto start once the conversion is complete. Please click "yes" to go ahead.
Step 8: Select "next" the system will just look up for burning equipment.
Step 9: Check burner "Settings".
Step 10: Click "Start" to begin burning.
I hope you've found this helpful. Thank you.
