In Techyv.com “Ask a question” how can I paste an image?
Hi All,
I have joined this awesome community to help people with SQL issues.
In Techyv.com "Ask a question" how can i paste a image?
I want to make the image show on the screen
Thanks
Hi All,
Thanks
When posting your question it techyv, the image that you want to accompany the question is not copied and pasted but it is uploaded instead.
In the menu bar where you see icons, you will see an icon that allows you to upload images to techyv as shown below:
You will need to click on the icon circled with red, and then another window will pop up. In that window, you will need to click on upload and then browse for the location of the image that you want to upload, and then upload the image.
Note that you should place the cursor where you want the image to be placed.
-Experttechyv
Hello Rahul, your issue about pasting an image in techyv.com interests me. I had the same issue when I started also. The best option is to upload the image from your computer and I have posted how you can upload it as well.
From the icons click the picture where it says image, see picture below:
Then, you will be routed to an option on what type of image you'd like to upload, see image below:
You can start uploading pictures now.
Another option is to copy the image or picture then paste it on the “Body” of your message. This will also work for you but you can do the editing unlike uploading it. Whatever works best for you for these options are good.
Notifications
