Hi there,
I have this unexpected error when some application is closed by themselves and fails to relaunch. I have a MAC with OS X Leopard. Recently I have made changes to my settings and it’s probably that I changed something that I shouldn’t. Can anyone help me to repair my MAC ? What I changed that caused this kind of errors ?
Thank you !
Tekkit Lite quit unexpectedly while using the libjvm.dylib plug-in.
Click Reopen to open the application again. Click Report to see more detailed information and send a report to Apple.
Ignore Report… Reopen
Tekkit Lite quit unexpectedly while using a plug-in
I think this is not a problem with the operating system rather with the program itself. If the plug-in mentioned in the error message didn’t come with the program when you install it or you yourself manually install the plug-in on the program, you only need to uninstall the plug-in to remove it from the application.
This will surely fix the plug-in error on the program. But in case the plug-in ships with the program, try reinstalling the app to see if it is only a corrupted file that’s causing the error. It is also a good way of restoring the program’s default files in case of missing files. Another way of fixing the problem is to install the latest update for the software.
You may also want to try installing the latest updates for your operating system.
