abel abel
Posted on - 01/31/2013
Hi experts,
I am using Windows 7 and installed advanced system optimizer on my computer. I am facing a problem with its protector. I want to resolve this issue. I don’t require the solution but I am looking for any advanced system optimizer forum. From where I can find different issues and their solutions. Tell me any best forum in this regard. Waiting for a quick reply.
Tell me about any advanced system optimizer forum
Hi Abel,
I am starting with advice for you to not be tempted by "optimizing" software for Windows. The best optimizing could be done mechanically.
You can turn off Windows services you don't need, stop third-party processes in Task Manager, update your VGA drivers and so on.
Despite my words, you can find solution to your problem in here.
Just read it carefully and you should deal with protector problem you are having.
Best wishes to you.
