Tell me about Freeware router for vmware
Guys how I am going to configure the virtual machine vmware to support and act as like a LAN router in a specific networking project. Connecting two computers in the same router, tell me more about this. This is very important to me because I am taking a networking subject and I am having a hard time thinking about my lesson.
Best Answer by Vinson forman
Answered By 0 points N/A #159552
Hello Adolf,
The shortest approach to that will be to manually install the vmnetcfg.exe. Virtual Network Editor, and after that you can go ahead and then configure VMnet2 without DHCP and Host vNIC. After that, you will need to manually configure each Virtual Machine's Network Adapter to use Custom VMnet2.
Nicke
Answered By 0 points N/A #159553
Hi Dear,
Thanks for sharing your problem with us.
Kindly act as i am going to direct you to do.
First Check your All networks, is there any problem in them?
Are they Link correctly with each another?
If networks are all OK, then open Virtual machine Settings and first click on Hardware.
Then you will see the list of your attached hardware.
You have to choose Network Adapter From the list. And in front of this list, Settings of the selected hardware will be shown. In network adapter settings you have to choose "Bridged, Connected Directly to the Physical Network".
Now Go to "Routing and Control Access" Right Click on your Defined Server and click on "Configure"
Press Next and Select Configuration LAN Routing.
Then You choose Correct IP Address Addresses.
And Enjoy
