I would like to know which level of accuracy can guarantee to converted files the java to vb converter. I would like to use it to convert those files for reducing the amount of manual work, but I worry if that will give the increasing of correction work so there will be no benefits from this software for converting the files. Am I right?
Tell me about java to vb converter accuracy
Hi there,
Converting from java to vb manually is very painstaking. You can download java to vb converter which is very accurate in converting java code to vb. It is very accurate even with poorly formatted java code. If you have to make any changes, this software will display warnings, notes and comments which will be useful to modify code. Overall, it is an excellent converter, easy to use, converts thousands of lines of code in minutes and very responsive.
You can check it out here- https://www.tangiblesoftwaresolutions.com/product_details/java_to_vb_converter.html
