Tell me about the motherboard repair step by step. A process on which to repair the motherboard is very important for it to be a successful one. I need your help guys for I am not an information technology expert but I can follow an instruction properly. I really need to resolve this matter soon.
Hi Benjamin,
As you know, from Google you can find a lot of forums but the chances of getting the right solution depends on where you post your problems. We have so many different forums to get knowledge about repairing of motherboard step by step.
So classifying and posting them on relevant forums is the best way to get your answer step by step. I can suggest you a good site, which is listed below:
If you haven’t done motherboard repairing before I recommend you not to try with your PC Motherboard. Because with a small mistake you do your motherboard will be unusable forever. If you want to repair it find a good technician. I have found many cases that Motherboard cannot be repaired and need to replace with a new one. This kind of stuff requires practical knowledge than the theoretical knowledge. So find some Motherboards that are not been used anymore and play with it. In few weeks you’ll gather good knowledge.
1....
