I would like to have some information about using the multimedia catalog template. It requires too much work to find the elements, which I have to use often in my work. They are mostly same all time. Which are the way to reduce my searching work, please suggest!
Tell me about multimedia catalog template using
Hi Arthur W Adams,
Well your problem is quite simple. You basically need to create an icon on your work page that contains your frequently used template. Now in order to achieve this you need a good software. I personally use Amaga web buttons but Ultra buttons is equally good for the task. The only difference is that the former is free and the latter is not.
Hello Arthur W Adams,
              Here if you want it then you have to download that from the link given below. All you need is to go the link and you have to download that software. It can manage all the things that you want to do from a multimedia catalog template. It is a free software and you can understand it very easily because it is not a tough one. There is the link of that software.
http://multimedia-catalog.suggestsoft.com/
