Tell me the best ac3 editor with graphical interface.
Hi everyone,
I want to edit my ac3 files using a graphical interface and reencode to ac3 format again with the keeping its original quality. Can you help me to find the best ac3 editor which has above characteristics?
Malaka Sanjay
Best Answer by stoll baker
Answered By 0 points N/A #162365
You can use a software called Audacity, this is a free software that is able to edit AC3 files. To download it, follow this link: https://sourceforge.net/projects/audacity/
After downloading and installing it, you have to download additional plugins from https://sourceforge.net/projects/audacity/plugins These will enable the software to be able to edit the AC3 files.
Answered By 0 points N/A #162364
You can try any of the software below:
  • Aften
  • Audacity
  • BeLight GUI for BeSweet
  • GoldWave Editor with ac3 plugin
  • Nero MediaSuite Wave Editor with ac3 plugin
In my experience, Often does the job quite well and it is also a freeware. You can download it from: http://www.afreecodec.com/windows/aften-48599.html
Also, you can try Nero. If you already have Nero 6, the wave editor is free and you can download it from: https://cd-rw.org/. With this, you not only can you edit your AC3 DVD audio files, but you can also use this tool to convert any other audio file formats into AC3.
