Tell me the best oracle report builder open office use.
My operating system is Windows XP and I use open office software package. I want to practice report builder program and learn to manage oracle reports. Please tell me how to get good  oracle report builder open office use and how to install server in my computer?
Best Answer by May Jratr
Answered By 0 points N/A #136354
Hello Beeky,
You can install the server on your personal computer using this URL
http://www.softpedia.com/get/Internet/Servers/Server-Tools/Report-Builder.shtml
and referring to this link http://www.object-refinery.com/jfreereport/index.html
You can learn and manage the Oracle reports easily.
Go through the first PDF. It contains various information regarding to building the report, and various examples which you
can practice.
Hope this solution will help you.
Thanks
Have a nice day.
Answered By 0 points N/A #136355
Hello Beeky Kaitlyn ,
Hope that my message finds you well.
The Oracle Open Office has a flexible and easy database client and it is easy to create and build database report/sheets from HSQL,Oracle, MySQL and any other types.
If you want to download it please follow the below URL:
https://extensions.openoffice.org/project/reportdesign
To install the server on computer please follow the below steps:
– Download a free server operating system. You can use the following link:
https://www.ubuntu.com/
– Burn the files into a CD.
– Insert the CD in the computer and restart your PC.
– On startup choose the option to boot from CD.
– Install the system in the computer.
– Follow the instruction that appears on the screen.
– Remove the CD from your PC once the setup is finished.
– Restart your computer again.
– Connect the server to your internet.
– You can start with your server.
Hope this solution will help.
Kind regards,
