Jeo Tolbert
Posted on - 11/27/2012
I want to capture screen shot while I am using Skype and I need to save that file in jpeg format and edit using Photoshop. Then I want 1200*1800 dimension (4 in* 6 in) jpeg to photo print.
Please tell me best screen capture freeware to make hi resolution jpeg files and how can I change its settings according to my requirement.My OS is Windows XP.
Tell me best screen capture freeware to make hi resolution jpegs
Dear Jeo,
Below is some help full material for your query.
Included in Windows 7, Windows Vista, and the Experience Pack for Windows XP Tablet Edition, the Snipping Tool fits into a perfect niche for many users. For those of you who don't need high-powered screen capture tools, the basic functionality of the Snipping Tool allows you to capture the whole screen, individual windows, or user-specified capture areas.
Snipping Tool also has extremely basic editing functions, like the ability to highlight and write on your screen captures. It lacks the more advanced features included in other screen capture tools, but it does a great job filling the gap between the frustrating Print Screen and Paste style screen capture in earlier versions of Windows and more advanced applications.
Snipping Tool is a solid choice if you've already got it on your system and your screen capture needs are minimal and far between.
You can download snipping tool for your OS at the link below.
http://xpsnipping.codeplex.com/
Regards, Kurtt
There are many ways on how to capture image in the computer by using the print screen on your keyboard and paste in paint then save it in jpeg format. That is the traditional way of capturing image, now snipping tool is now introduce to later version of Microsoft windows. You said that your operating system is XP right?
Now there is already snipping tool software for windows XP, that can now available and downloadable in the internet (see http://xpsnipping.codeplex.com/). Download and install the software and used it in capturing picture at high resolutions.
Regards!
Hello Jeo,
Quick Screen Capture make easy to take and print screen shot and add annotation on it, Quick Screen Capture is a screen capture as well as image editor you can take Screenshot from any part of your screen with more than 10 ways according to your desired format you can save image in BMP/JPG/GIF formats with supports of hotkey and auto saving.
In less time period you can capture an exact area with the help of Quick Screen Capture software, you can define your own hotkeys and automatically save captured images. It supports start minimized run in the system tray area.
