Tell me good jpeg fonts recognition software.
I have many pictures with sentences in jpeg format and I want to change that sentences using Photoshop. I have decided to use same picture or similar one and same font type. But many font types are difficult to understand (recognize). Please can you tell me is there any fonts recognition software to identify font in jpeg format
Best Answer by Bowl Louise
Answered By 0 points N/A #152920
Hello
You can use JOCR. It allows you to capture screen and read text from it. You can select part of screen or whole desktop. Using that method you can capture your jpg picture and read text from it. After capturing text is saved in clipboard and you can paste anywhere you want. To use this program you have to install Office 2003 or higher because of some libraries are needed.
You can download it from here: http://home.megapass.co.kr/~woosjung/Index_Download.html
Answered By 0 points N/A #152921
As long as you have many pictures to process, please consider using ABBYY FineReader® 11, I have used it for a long time and I could say it’s the best OCR reader I have ever used.
The software has many features like supporting Multilanguage’s, export text to many formats like “Word, Excel, PDF” and much more.
You can download it from the following URL:
https://www.abbyy.com/en-us/finereader/?redirect-from=old-fr-pro
Trienity Maria
Answered By 0 points N/A #152922
Hi Vera Pascual Agustin,
You can convert your JPEG file at work, you just have to go to https://www.onlineocr.net/, register there, then upload the file you want, and it will create a Word file. It's a very simple process, you can do it easily. I hope you get of rid of your problem.
