Tell me how to configure multiscreen on Windows 7?
I have windows 7 ultimate 64 bit installed and was wondering if someone may tell me about how to configure my OS to run on multiple LCDs?
In other words I want to use multiple Displays for single PC.
Can anybody help me with this?
Any kind of help would be appreciated.
Answered By 10 points N/A #133626
Hello Matland,
There are twp ways you can use to setup multiple monitors in Windows 7.
  • You can either use a keyboard shortcut or
  • You can use the traditional system properties.
When you choose to use the keyboard shortcut, you will need to simply press the Windows key and P (Windows + P) in order to bring up a quick menu of options.
After that you can choose the option you want form the ones in the image above.
If you choose to use the second method, you will just need to right-click on the desktop and then choose Screen resolution.
There will be several options to choose from the window that will appear, so just choose the option you like.
Carl
