I would really enjoy the OneNote application on my BlackBerry PlayBook phone. The only problem is, that I couldn't find any download, or link towards the application. I have searched online for a solution, but don't know where I could get it. Maybe you guys can tell me how to get OneNote on PlayBook because I am tired of searching and finding 0 results. Thank you in advance for your help.
Tell me how to get OneNote on Playbook phone
Hello John,
OneNote is a great application while in your phone and I understand what you are going through missing it. You are not guaranteed to get this application for free but it comes with a cost. While reviewing your problem, I came across the link below and I thought it would be of help to you.
http://appworld.blackberry.com/webstore/content/136370/?lang=en
This is the quickest and most practical way to connect your system with Microsoft company OneNote.
MobileNoter SE 4.2 allows you to:
• View and modify your notices in exclusive OneNote structure and layout
• Create new segments
• Add new WebPages
• Add pictures
• Perform with hand writing notices (inks)
• History sound notes
• Look for through the notes
• Look through the labels summary
• Perform with Security password Secured sections
• Sync the app with Drop box, Sky Drive and MS SharePoint storage
• Add icons to your house screen
You can also watch a clip that will add knowledge to you about OneNote on the link below. If you have time watch the clip it will make sure that you find it easy to use mobilenoter.
And learn more about OneNote on http://www.mobilenoter.com/
