Tell me how to join rmvb files freeware?
I’ve 6 parts of an interview video and want to upload them to my blog. But I want to upload whole interview not in parts. Does anybody know how to merge these videos into on video file? These videos are rmvb files, so tell me how to join rmvb files freeware.
Answered By 10 points N/A #132962
Hello Roger,
There are various applications that can help you merge your videos. It will depend with the format that you have saved the file in. Some of the most popular softwares that you can use for merging the videos are:
  • The Ultra Video Joiner.
  • VirtualDub
  • AVS Video ReMaker
These applications are freeware and therefore you can easily and readily get them on the internet. Make sure that you check the system specifications of your computer, whether it supports 64 bit or 32 bit application, and then download the right application that matches those specifications.
Hope this helps.
Carl
