What I am asking may be complicated now. I have tried to design a player in Flash.
So far it is not looking bad.
The only thing that I don't know and haven't found a solution to yet, is how to make equalizer bars colorful for the player.
Taking in consideration that I am not an expert,
I require if possible some simple instructions or very well detailed complex ones.
Thank you in advance for your help.
Tell me how to make equalizer bars colorful in Flash
The equalizer bars can be made colorful for a player in flash by following these steps:
Go to Windows > Color Mixer > Click paint bucket > In the Type Menu >Select Linear
On the linear gradient stripe, click between the existing squares on three or more squares (depending on your choice to add colors) to add these squares.
Click on a square and add hex color value, each square will have a different value to make bar colorful.
Select the paint bucket tool and click on top of rectangle and drag to the bottom, while holding Shift key to create a perfectly vertical linear gradient fill.
