Hello experts,
I am newbie to Mac. I want to ask a question and its solution from experts. I want to take parallel screen shots and also want to paste them parallel. I am searching for the way how to paste screenshots in parallels? Any suggestion and tips are welcomed. If I have to install some software then it should be free and user friendly.
Thanks
Tell me how to paste screenshots in parallels?
Hi Brenda,
There is a smart utility in Mac by default which you could use to do this task. It is called Grab Utility or the Terminal. Go to Applications/Utilities/Directories. Find this tool there or you can also launch this with Spotlight by Command+Space. I like Grab most because it is more user-friendly and doesn’t need the command line. After launching Grab hit Command+Shift+Z which will bring up the timed capture alert dialog. When you are ready to take screenshots Click on “Start Timer” and see the magic.
