Ruth E Tran
80 points
Posted on - 05/08/2013
I have a bunch of PDF files that has a certificate security. I want to know how I can remove it easily? Or if it's possible, please send me details on removing it and how valuable is it to remove those securities?
Tell me how to remove PDF certificate security easily?
Hello Ruth
These are a few ways you can unsecure your certificate secured pdf;
Put the file at Google docs choosing Convert image or pdf file as google docs file option.
The file will then be extracted by docs to Google docs format;
You can now rearrange and do corrections;
Google docs limit’s pdf files to 2MB.
OR
You can open it on Adobe acrobat as owner. On the task toolbar, click on secure button with icon of a padlock on it, and select to remove the security alter encryption settings rater than unsecuring totally by selecting to show security properties menu with the secure button instead of selecting to remove security option and put in different encryptions then click next and follow. Â Â
