brysaab
Posted on - 10/31/2011
Hi all ,
I have an Outlook PST file saved in USB drive.
And I want to use it both in Windows and iMac outlook.
Is it possible to use that single file on two different operating systems?
Can you please help me?Â
Thanks
Tell me if is that Possible ????
Hi Brysaab,
Yes it is possible to use the single file on two different operating systems like the Windows and iMac Outlook.Â
It is called Hard disk drive partition. It divides your hard disk drive to create units of different logical storage mentioned as partitions. Then, what is good about it? Â
When you are able to create multiple partitions it also allows you to separate the Operating System and files in your program from the files of the USER. Â
In which also enables you to permit the back up of image to be created of only by the Operating System and downloaded software. In addition, using of multiple boot set ups permits the user to have different Operating Systems in just one computer. Â
Just like what you're going to do.
You could install Windows and iMac Outlook or any other OS on multi partitions of the same disk and have an option of booting into any mixable operating system.Â
Hope this might help you.
Thanks
