Tell me more about upgrading from dolphin 6 to dolphin 7.
Hi everyone,
Tell me more about upgrading from dolphin 6 to dolphin 7. I have no experience about upgrading software from one version to the next level; there are so many instances that needs to be considered regarding that matter. I just want to get some idea on the compatibility measurements.
Answered By 0 points N/A #184679
There are some factors you should consider about before migrating from Dolphin 6 to Dolphin 7. I will provide you with some links that will help you in order to follow the correct installation process.
 * If you want to install Dolphin 7 to your system this tutorial guide will help you to do the installation. All the system requirements such as web servers, domains are listed in the below guide. Follow the instructions correctly and everything is explained clearly there. Please visit the below link to access toward the installation guide.
https://www.boonex.com/trac/dolphin/wiki/DetailedInstall
* If you just want to migrate from the Dolphin 6 to Dolphin 7 the below will help you to perform the task. All the installation instructions for the upgrade is mentioned there. Please refer to the system requirements from the site mentioned at the top before the software upgrade.
https://www.boonex.com/trac/dolphin/wiki/6.1.6to7.0
