Tell me more about windows paint and paint mountain lion mac?
Hello techyv,
I would like to ask some important information about the difference between a windows 7 paint application and a mac paint application.
Which is the most reliable and comfortable to work with?
I hope you can give me some advice.
Expecting some help from you guys.
Hi Bryan,
Windows 7 paint application is like Mac paint application no major difference between them like both have free form selection, select, color eraser and eraser, pick color, fill color, pencil, brush, magnifier, airbrush, line, text, ellipse, rectangle, polygon, curve and rounded rectangle etc.
These all are main features which are used in this simple application. If you are use too with Mac then it's comfortable for you to work on if you are comfortable with Windows then its ok it depends on user.
