Telnet Problem: Web Interface Hs
After enabling Telnet and ipkg, I have a problem with the web server that no longer works. I wanted to know if someone has already experienced this and if there is a solution?
Network drives do not work, but it is still accessible by telnet. I would like to avoid reformatting the hard drive. Â So, if there is a solution to this problem I'm interested.
Here is the error :
Internal Server Error The server encountered an internal error or misconfiguration and was unable to complete your request. Please contact the server administrator, admin and inform them of the time the error occurred, and anything you might have done that may have caused the error. More information about this error may be available in the server error log. Additionally, a "500 Internal Server Error" error was encountered while trying to use an Error Document to handle the request. Apache/1.3.33 Server at xx.xx.xx.xx Port 5000.
