Template of daily task for Mac OSX
Hi Techyv Friends,
I would like to have a template of daily task for Mac OSX, Please do let me know about, where to get the mentioned template.
Dave Tuttle
Hi Techyv Friends,
Dave Tuttle
The daily maintenance tasks for Mac OS X are automated, but it can still be beneficial to run the script manually.
Mac OS X runs routine background maintenance to keep the system running smoothly, primarily by helping manage storage space. This is limited to cleaning out un-needed system files and so the bulk of the file management will still fall on you.
Also, the automatic daily maintenance tasks occur every day at 3:15AM local time and if your computer is off or in sleep mode it will not receive the maintenance. So, to run it manually:
Open Terminal in the /Applications/Utilities folder. You'll see a prompt and a cursor like this:
Enter “sudo sh /etc/daily” into the Terminal window exactly (note the space after “sh”). Then hit RETURN.
Enter your Mac OS X Administrator password and hit RETURN again. The Terminal window will show you a read-out of what it's doing, and then present you with another prompt to quit Terminal. That’s it.
