Template for mobile website development
Is there a template available for jQuery or non jQuery for mobile website development? Where can I find one?
you can find mobile website template from this:
http://www.tripwiremagazine.com/mobile-website-templates/
https://www.wix.com/website/templates/html/blog
https://www.templatemonster.com/free-mobile-templates.html
https://www.templatemonster.com/blog/mobile-web-design-trends-2011/
If you are looking for a template to use maybe on your mobile website, you can use Artisteer 4.0. It is an application for creating different web templates which you can then apply to your website. With this you can create or design your own HTML template without having to go through those tedious parts of designing an HTML page and creating the webpage’s separate CSS and JavaScript files. With an HTML template, you have an instant webpage with just a few clicks using the software. Unlike previous versions, Artisteer 4.0 features the “Responsive Web Design” function which makes the page adjust to the browser’s screen resolution. You can set this to “Yes” or “No”.
Responsive templates in Artisteer are designed for the optimal viewing experience on desktops, tablets [Landscape and Portrait Layouts], and Smartphones [Landscape and Portrait Layouts]. Using Artisteer, you can create HTML, Joomla, WordPress, Drupal, DotNetNuke, and Blogger templates. I’ve already used it just to see what the final output looks like and what I learned is that with this software, you can generate unlimited web templates with unique design. You can download the free trial version, Artisteer 4.0 for Windows and Artisteer 3.1 for Mac OS X 10.5 and 10.6 from Artisteer – Web Design Revolution | Download. Artisteer 4.0 supports Windows XP, Windows Vista, and Windows 7 and requires installing of Microsoft .NET Framework 3.5. This version requires around 1 GB of RAM and at least 1500 MHz processor speed. This supports WordPress, Joomla [1.5 – 2.5], Drupal [5.x, 6.x, 7.x], Blogger, DotNetNuke [5.x, 6.x], Artisteer.net, HTML 5, and CSS 3.
