Templates created using Adobe Photoshop
Hi expert, I need some 2012 calendar templates. Templates must created using Adobe Photoshop with colorful background images. Please provide the download link and other instructions. Thank you.
Hi there!
If you need some 2012 calendar templates with colorful background images, you may click this link: https://www.calendarlabs.com/2016-calendar-templates.php and choose from different template designs provided. To download the file, just click the Download link below the desired template and the .doc file will be automatically downloaded in your computer.
Hope this helps.
Greetings!
If you want elegant design for calendars with PSD file extension. This is the best link to download templates for calendar in Adobe Photoshop Extension or .PSD. Visit this link and search for the best calendar templates which suites your taste.
http://pngframes.net/photoshop/calendars/
I hope this link will help you get the templates you want.
Best Regards,
Jose D Dunn
