kurt tedo 10 points N/APosted on - 08/24/2013
I have been using Samsung Galaxy Ace recently I brought Velocity Micro T301 Cruz 7 Inch Android 2.0 Tablet. I used to play Temple Run in my Galaxy Ace which I downloaded from Play Store but Temple Run wont work on Cruz, I have downloaded it but is unable to open it in my Cruz, Please guide me.
You have to have your Android Tablet's Operating System up to date, otherwise it won't work. Although, your game must be downloaded from the Google Play Market, otherwise it won't work again. The reason is that Google wants to keep its clients connected to the market, so the games downloaded from another source won't work on your tablet.
If the “Temple Run” game you downloaded from the Google Play store works on your Samsung tablet but not on your Velocity tablet, check the Android version running on your Samsung tablet and on your Velocity tablet. Your Velocity tablet runs on Android 2.0 Eclair. There are two versions of the game at the moment: Temple Run and Temple Run 2.
Temple Run
If the version you want to install on your Velocity tablet is the first version, Temple Run, I don’t think it will install on your Velocity tablet because the existing platform on your tablet is not supported. To install and play the original “Temple Run” Android game, your device should be running on Android 4.0 Ice Cream Sandwich or higher.
The game will not run in older Android platform like Android 2.0.
1....
