Temporary folders cannot be deleted
Asked By 7060 points N/A Posted on -
I am using Internet Explorer 7.0 on my Windows XP computer.
There are some files in my Temporary Internet Folder that I cannot delete at all.
What' the problem look like?
Is there any way out to solve the problem ?
Best Answer by stan4567890
Answered By 0 points N/A #79966
Please install "ccleaner" software to your computer. It removes unwanted files and also it removes your unwanted registry entries Therefore it make the computer fast enough to perform multiple task. daily use of this software will make your computer free of any browser crash.
It deletes all the temporary files and also deletes the web pages you have visited. It is really a helpful software and you should use it too.
Hope it has helped your query.
Answered By 0 points N/A #79967
Our first option is to close your internet browsers and all applications that has connection to the internet or any relation to your internet browser. After closing all those applications, navigate your temporary internet folder then select the folder or temporary files you want to delete then press the delete key.
If still you can’t delete your files in the temporary internet folder, you may boot your computer to safe mode then browse the temporary internet folder then delete all you want there. If still you can’t delete the temporary folder, take ownership of that folder to have the full control permission then do the delete after taking ownership.
