Term for implementing a pattern
What is the actual term called for implementing a pattern, which is the core solution of a problem, which occurs repeatedly in an environment? Please help.
Hello Floella,
It depends in the environment that you are in and from which point of view are you looking the problem at. Since the pattern is repetitive, we can refer to it as a regular expression or design pattern which is required to be repeated a number of times so as to come to a conclusive solution that will solve the problem that someone may be having. The repetition might be going through one step or a series of steps.
We can also say the patterns repeats itself due to some bug or incorrect results hence repeating is a way of trying to find the absolute best.
__
Regards
Lee Hung
