The terminal server has exceeded the maximum number of allowed connections.
While I am trying to log in terminal server as an administrator, a message appears and decline log in.
The message contains "The terminal server has exceeded the maximum number of allowed connections.
I have tried several times, but each time this message appears and restrict log in.
Please share your experience regarding this issue.
Lina
Answered By 0 points N/A #88897
Resolving the error: "The terminal server has exceeded the maximum number of allowed connections
When a user establishes a Remote Desktop connection to the server this connection will remain active until the user selects "Log Off" from the Start Menu.
 As such, if a user simply closes the remote desktop window when they're finished with the server, that username will remain logged on.
The software running on the server to facilitate the Remote Desktop connection will allow for up to two simultaneous administrative sessions.
If a third attempt is made to login to the server, the error discussed here will be shown to the user, and they will be unable to complete the login process.
To get around this error and log into the server, you can log into a special session call the Console Session in order to Log Out the other connections.
To do this, simply type the following in a Start > Run or Command Prompt.
mstsc /server/computer name or IP address /admin   this will log off any active sessions that were not logged off.
Login with your user name and password
