Terminating Android Application Using Task Killer
How do I terminate an application on Android? I can move it aside but it is still running in the background. How do I stop it from running completely? At the moment, I have to switch off the device to get rid of all the running applications. Is there an easier way?
Is there a task manager which I can select and say kill application?
