Nevikenezer
40 points
Posted on - 09/16/2012
Hi. I spend my vacant time playing this; it was fine until yesterday this error message showed up.
Can you help me on this one?
I don't want to stop playing this game.
Terraria
No suitable graphics card found.
Unable to create the graphics device.
Thanks,
Nevi
Terraria problem. Error message: No suitable graphics card found.
Hello.
There is a problem with your graphics driver.
May be the driver has run into a problem or just crashed.
Check with your device manager for the graphic driver and check whether any hardware changes were made.
I you find any changes uninstall the graphic driver and install the fresh copy or the updated version.
Thank you.
Hello Nevikenezer,
Just simply do a System Restore of your computer to an earlier date in which you are sure that the computer was working.
I hope you know how to do a system restore. It is a bit easy in Windows Vista and Windows 7(Just type System Restore after clicking the start button to search the program).
For windows XP, click on Start, then Accessories. Point to System Tools and then click on System Restore. Follow the on screen prompts to restore the computer to an earlier date.
Alternatively, you can re-install your display driver to restore your graphics driver to a normal state. If you know the type of graphics card in your computer, go to the publisher's website and download the drivers and re-install them in your computer.
Go to Device Manager by right-clicking my computer, and clicking on properties. Choose Device Manager and check the currently installed Display driver to get the name of the available graphics driver to re-install.
This should work just fine.
