Test Connection error changing the application location
I have developed a web application located in program files folder. I am using Windows Server 2008 R2 and running IIS7.5. When I tried to create a new application within IIS and set the location to the same folder and click Test Settings an error message displayed. Is this a problem with IIS? How can I avoid this error? Help me with a strong advice. Thanks.
Invalid Application Path
Test Connection
There was an error while performing this operation.
Details:
Invalid application path.
Answered By 15 points N/A #171251
Hi Willie,
The error is because the bindings in IIS are not correct.
There are multiple solutions to resolve this error.
Solution 1: Change the HTTP bindings in IIS.
1) Open the IIS Manager
IIS-Manager-window-to-open-website
2) Select Web Site, Click 'Bindings'
3) Select 'Add', Enter the host name for the specific website
4) Restart the IIS
Solution 2: Changes in the application pool identity.
1) Go to IIS Manager, Click on 'Application'
2) Enable the Anonymous Authentication mode
Anonymous-Authentication-enabled-status-window
3) Click 'Edit', select 'Application pool identity'
Application-pool-identity-for-Authentication-Credentials
4) Click 'Set', Enter the login credentials in the set credentials window
 Credentials-for-Application-pool-identity
5) Click 'OK'
